Rake Mid mount rake
   / Mid mount rake #1
Anonymous Poster
Epic Contributor
Is there such a thing as a mid mount rake ? All the rakes I see are for 3 point hitch. I plan on getting a 3-point rake but thought a mid mount would do a better job having wheels before and after.
   / Mid mount rake #2
If you get a guide wheel(s) with your rake, it has wheels on both sides (the Guide Wheels /forums/images/graemlins/grin.gif and your Tractor Wheels). Adjusting the length of the toplink will "tilt" the rear guide wheels up or down in relation to the rake tines, allowing you to regulate how much bite you take with the tines. As long as your tractor has position control on the three point hitch, so it stays where you set it, you get the same effect as if you had a MM rake. Since there is no down pressure on the 3-pt, it will raise slightly when your front wheels go over a bump, and the rake will not dig (much) deeper. When your rear wheels go over a bump, the rake tends to take the top off the bump. Clear? /forums/images/graemlins/confused.gif
Recommendation: When you get the rake, make sure the guide wheels do not attach to the ends of the rake, or they will stick out beyond the rake when you angle it to sidecast the material you are raking -- or when you are trying to pull material away from a fence or wall and move it back towards the tractor. On my 6' Leinbach rake, the guide wheels attach about 12-16" in from the ends of the rake, so the wheels follow the rake and do not swing outside the path covered by the rake when it is angled.
2020 CATERPILLAR 938M WHEEL LOADER (A51242)
2020 CATERPILLAR...
2 pt IH Sickle Bar Mower (A50515)
2 pt IH Sickle Bar...
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
JOHN DEERE 9650 COMBINE (A51243)
JOHN DEERE 9650...
100 Safety Cones (A47384)
100 Safety Cones...
2024 New Holland T8.410 MFWD Tractor (A52128)
2024 New Holland...
