Mid Mount Mower
   / Mid Mount Mower #1
HP942
Poplar Bluff, MO
LS XJ2025H
I know what they say about opinions….but. I am finalizing my wish list for a new/new to me tractor. I’m currently mowing about an acre of my 3.5 acre lot with my old JD and a 6‘ finish mower. I am planning on moving to mid-large frame compact. I think I want a MMM, but some dealers swear by them and some swear at them. Who has moved from a 3pt finish to a MMM or vice versa and been happy with there decision and why. Thanks,
   / Mid Mount Mower #2
Two thing I don’t like about rear finish mowers. With a mid mount just the front wheels mash down the grass, but with a rear one, both the fronts and the rears mash down the grass. The rear mount swings into an object as you turn away.
Rear finish mowers can do a good job and if you get up near 40 hp you can get a really wide one. They are also easier to hook up usually but I bet with the auto connect on my JD I can match the ease of hook up. Rear finish mowers are usually cheaper to.
Mid mounts seem to be a love it or hate it thing.
   / Mid Mount Mower #3
A mid mount is troublesome to take on and off and is too restrictive to do most tractor work with. A large frame cut is too big to be a good lawnmower anyway. I’d save your money and either keep using the finish mower or buy a ZT.
   / Mid Mount Mower #4
Opinions follow, your situation may be different:
Buying a mower deck for my CUT was a very dumb thing to do. Wresting it on and off isn’t a whole lot of fun. Installed it pretty much limits work to graded/flat surfaces, else the probability of damage is high. Puppy wasn’t inexpensive either. From a cost standpoint, the hefty price paid for it would have gone a long way towards buying a quality standalone mower. If we’re not talking hills and dale, a stand alone mower could have been cheaper.
Pulling/installing the deck isn’t rocket science, but it is heavy, awkward to move into and out of position, and is fiddly to adjust. Maybe all that's changed with the drive over option. Once up and running, the quality of the cut is v good, better than my X500.
As mentioned, tooling around a yard with obstructions (trees, well, septic, house etc.) in a long vehicle require more operator attention. Can’t go under things with the tractor due to its height. Always thinking about ground compaction when traversing near the leach field. Industrial tires leave marks under certain conditions. Which is why I mow with the X and put up with the not so great cut.
Mow 2 acres with the X, use the tractor for grading, skidding, brush/tree collection, hogging and everything else on the remaining 38. Used the MMM three times over 18 years, look at it daily hanging from the wall.
Bottom line is because of frequent off road uses for the tractor, having a MMM deck installed is a no go. And it’s hard enough to install/remove that getting a dedicated mower was worth the cost. To me.
You may be different.
I'm assuming the non lawn portion of the 3.5 acres is wooded and or requires some sort of ground engagement, thus the need for a tractor?
   / Mid Mount Mower #5
I had a MMM for my old JD855. Just a PITA to take on and off and ended up using a Husqvarna 48" rider. Now, I am upgrading to a Bad Boy ZT. Maybe the new MMM's are easier to put on and take off, and in my case I do not want to keep a MMM installed all the time.
If you can keep the MMM on all time, should be OK. But it will still be a a hassle to change and sharpen blades. You can get a decent ZT for not much more than a MMM and it will cut grass and twice the speed.
   / Mid Mount Mower #6
I can't say mine is either easy or difficult to mount or dismount. Takes some getting used to. Ground clearance can be an issue.
One thing I didn't see mentioned above ---- some machines can only use either the MMM << OR >> a rear 3 point implement. They require you to remove one or the other. Others, like mine allow you to have both on and be able to use both.
   / Mid Mount Mower #7
Yep,
Learned this after the fact, that i need to remove my backhoe to use my mower. Good Stuff (not)
   / Mid Mount Mower #8
Every situation has a proper tool for the job. I started with an old Mitsu MT180D with a RFM and then bought a newer MF SCUT with MMM. If you had mostly level acreage and few slopes, then an easily unhooked RFM might be right for you. If you have slopes like I do, making those end turns with an RFM leads to tail-wags-dog types of issues. My MMM is a drive-over, so it isn't too awful to attach; attachment of the mid-driveshaft is the 'hard' part and if you are able to kneel down isn't terrible.
My drive-over MMM actually has caster wheels for setting the height (so I don't have to use the mid-mount cutting height selector) and the weight can stay on the ground/wheels and not the suspension/lift system. The smaller, light-duty MMM have anti-scalp only and do rely on the mid-mount height selector.
I did actually figure out that if I let my grass get too long, I can use the MMM at full up/lock and pull the RFM and run both PTOs simultaneously to get two cuts per pass. And I don't need a bush hog.
   / Mid Mount Mower #9
Did somebody mention MMM?
   / Mid Mount Mower #10
Both have good and bad points! mids are better since only the little front wheels mash grass down, BUT they are a problem to get the deck out to work on it. also cant mow close to anything.
with 3-pt mount the whole tractor runs the grass down, but you can back right up to something with them. Not really hard to put on or take off!
out fronts are the best of all mowers!
UNUSED FUTURE LASER LEVEL W/ TRIPOD (A51243)
UNUSED FUTURE...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
2023 BANDIT SG-75 STUMP GRINDER (A51242)
2023 BANDIT SG-75...
1998 SHERMAN +REILLY 6048 SINGLE DRUM LINE PULLER (A50322)
1998 SHERMAN...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
(8) TRACTOR WEIGHTS (A51244)
(8) TRACTOR...
