Mid Engine Rider. 13.5HP
   / Mid Engine Rider. 13.5HP #1
Curly69
Bronze Member
Henderson County, NC.
2006 JD 2305
I have a small Craftsman Mid-Engine Rider Model 536.270302 made in 2005.
Broke it out today and started up no problem. let it sit a while and off I went.
After about 5 minutes it just stopped moving, no forward or reverse. Figured it was the belt but all looked good. From what I see the Pulley Stack is just sitting there, the drive belt is good but off. You can take the PS and move it up and down 3-4 inches. Are these bolts known to come out or do they break? The schematic is just showing a bolt, washer and lock washer no sheer pin or pin of any sort.
I will have to take the deck off to see what happened.
Any opinions?
OK put everything back together, seems as though the bolt just came out. Found washers and bolt on the deck.
Now it's back together it only wants to move when I hit the break/clutch could I have messed up the idler pulley?
3 point Woven Wire Rack (A53117)
3 point Woven Wire...
Metal Peacock Lawn Art (A51694)
Metal Peacock Lawn...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2015 Ford Focus Hatchback (A51694)
2015 Ford Focus...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
