39President
- Joined
- Jul 16, 2007
- Messages
- 23
While dealing with my ignition switch problem, I was looking under the hood at the firewall, there is an opening about in the middle, you can see into the back side of the dash. I saw a bunch of straw, twigs and all sorts of bedding. I removed the lower panel of the dash to reveal a totally filled area with mouse bedding, pee and poop. What a mess. Used a vacuum cleaner and compressed air to clean it out. Lots of wires in there, I was lucky, no damage. While I was doing this work, I looked at the lower front edge of the seat and saw the tell tale black ooze of mouse pee coming from under the seat. Moved the seat as far forward as it would go and looked in. All I saw was bedding and more bedding. The only way to get at it was to remove the seat at it's 4 mounting bolts. I used needle nose pliers, compressed air and a vacuum cleaner to get all that crap out. Because of the pee, a lot of stuff was stuck to the springs and other parts. Last step was to flush the area with a garden hose. I stuffed the under seat area and the under dash area with fabric softener sheets. The tractor is kept in a portable garage so I'm sure it's a great place for mice to live through the winter. Glad I found this now instead of the middle of winter, ready to plow and no start because of chewed wires. Hope this helps somebody!
