MH50 hydraulic pump shaft for Davis 101F - 6 SPLINED 3/4"x18"
   / MH50 hydraulic pump shaft for Davis 101F - 6 SPLINED 3/4"x18" #1
Anglersnet
Massey Harris MH50
The front hydraulic pump input shaft broke on my Massey Harris MH50 for my Davis 101F loader. The original parts book shows it as 1086008M1 with a THREADED end to the tractor. Mine is 3/4" but 6 SPLINED to the engine, sort of like Ford compacts except for the fact mine is 18" long not 9-13". I can't find a shaft like this anywhere. ACGO has the PN but again the end is threaded not 6 splined. I can't even find 3/4" 6-splined stock long enough to cut down, except maybe McMaster-Carr for a ton of money. Any idea what is going on with mine? It has the original Continental gas engine so a different input for the shaft confuses me. Thanks, Bob
   / MH50 hydraulic pump shaft for Davis 101F - 6 SPLINED 3/4"x18" #2
You need the help of a good machine shop. Make the shaft from a chunk of hyd rod stock (1045) and mill the splines on a milling machine using a dividing head or super spacer.
You may end paying close to the price of the stock presplined from McMaster ($250?), but the McMaster stuff still needs tweaking.
PAIR OF VACUUM PUMPS (A53843)
PAIR OF VACUUM...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
NEW HOLLAND TN75SA TRACTOR (A51247)
NEW HOLLAND TN75SA...
UNUSED GREAT BEAR 78" HEAVY GRASS FORK GRAPPLE (A51248)
UNUSED GREAT BEAR...
74in FEL HD Round Back Bucket (A53472)
74in FEL HD Round...
Polaris Side by Side (A50324)
Polaris Side by...
