MFWD oil level check question
   / MFWD oil level check question #1
bushhog28
nc
Massey 5611
Do you guys use thread tape, blue loctite, or something else on the plugs when you put them back in? Manual says thread sealant.
Thanks!
   / MFWD oil level check question #2
I use a PTFE base paste usually, but since they are not under pressure almost anything will work as long as its oil compatible. I don't use teflon tape for anything on the tractor(s), leave that for the plumbers.
2018 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2018 GENIE GS-1930...
SET OF (6) LADDERS (A53843)
SET OF (6) LADDERS...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
2001 JUSTIN 14 MOTORCYCLE TRAILER (A53843)
2001 JUSTIN 14...
