I've got a 65 that I saved from the scrap pile and restored from the ground up. It didn't have any gauges and the oil filter was broke off and bypassed. I put a new spin on filter kit and gauges on it and now it pegs a 100psi oil prress. gauge and blew out the o ring on the filter. I put a different brand filter on and installed a liquid filled test gauge from work and at idle it runs 130ish psi and will burry the 160psi gauge if you rev it at all. Even once warm at idle it still runs 85-100 psi and will still bury it if I rev it at all. I took the pressure relief valve out and it looked good (didn't seem to be sticking and wasn't scoured up) so I cleaned it with some emory cloth and put it back together with the same results. I can't find a spring part number or tension rating but was wondering if at one time the previous owner had low oil press. and put to stiff of a spring in to solve the problem. I'm about to pull my hair out so any assistance would be appreciated.
Thanks,
Wayne
P.S. I'm running cheap walmart 15w40 right now.
Thanks,
Wayne
