MF4707 PTO engagement issues (8’ Bushhog)
   / MF4707 PTO engagement issues (8’ Bushhog) #1
FF1854
MF 4707
Hello all. First time post, and no doubt from a rookie in terms of tractor technology. Will try to keep brief:
- new 4707, just had 50 hour service
- grappled and mowed (8’ new Hog) yesterday morning with no issues.
- continue to try adjustments for Hog level and cut quality; adjusted back support wheels on Hog one level to raise deck
- used rear linkage external controls multiple times to toy with mowing height; also used inside height controls
- when tried to start up PTO again to mow, I can hear PTO trying to engage (clicks) but the PTO shaft barely turns (or doesn’t turn) and I eventually get a flashing triangle warning light.
- adjust throttle does nothing (except perhaps trigger the warning signal)
Any thing jump out for a quick check? I’m not with the tractor now but thought I’d seek some input.
Thanks!
   / MF4707 PTO engagement issues (8’ Bushhog) #2
The first thing that jumps out at me is the warranty should cover it. You may have a weak solenoid or a poor connection if the PTO is energized by a solenoid rather than a mechanical engagement.
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
2007 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W97X154872 (A51572)
2007 Ford Crown...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
PENDING SELLER CONFIRMATIONS (A53426)
PENDING SELLER...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
