MF400 series ground speeds
   / MF400 series ground speeds #1
BER
Bronze Member
SW. Indiana
MF1235 HST MFWD
Would anyone know the ground speeds for the 8x8 SSS tran. when used in the MF461? The early broshure on the Massey web site listed them, but the newer version does not.
I could be wrong, but if the MF1455 with the 8X8 tran. running at 2500 RPM has a ground speed of 1.5 MPH ,then the MF461 with the same size rear tires and the 8X8 tran. running at 2200 RPM should have a ground speed of about 1.3 MPH. This is assuming the two tractor 8X8 tran. are the same.
   / MF400 series ground speeds #3
As the 1455 is mfg by Iseki for MF, I doubt that the two tranny's are the same. It would seem to me that if the ratios are the same it would be coincidental.
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52128)
2021 John Deere...
UNUSED MOWERKING QUICK ATTACH ANGLE BROOM (A51244)
UNUSED MOWERKING...
Set of Tractor Tracks (A50514)
Set of Tractor...
