MF383 starter wiring?
   / MF383 starter wiring? #1
G/F's MF 383 won't crank. I thought maybe the battery was dead, it's charged. I've washed the "dirt and mud" from the dash. The Ignition switch appears to be a 4 pole switch, turn it to crank and it looks like it's sending voltage out. At least it goes into the harness. I then started checking from the starter back. The wire goes from the starter solenoid, back to the neutral safety switch, I have continuity to and through the switch. I cannot open the hood because of the FEL. I know the PTO has a part in the crank circuit too. Is there a relay somewhere that's also for the start circuit that the PTO switch is wired through? I'd love to have starter wiring diagram. The FEL is a PITA to take off to just open the hood. I'm almost ready to rewire the thing if/when I can get to the PTO switch so it can't be cranked unless it's in "N" and the PTO is disengaged.
I'm swamped with "broke farm equipment" right now....SMH...
...All my wiring is approved by Undertaker Labs....
Bobcat Skidloader PHD (A50774)
Bobcat Skidloader...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
M & M Grain Drill (A50515)
M & M Grain Drill...
John Deere 6105D (A50120)
John Deere 6105D...
Chevy 2500 Pickup (RUNS) (TITLE) (A50774)
Chevy 2500 Pickup...
