MF35 lift pump question
   / MF35 lift pump question #1
ben.jones47
MF35
Hello
I’m new to all this so please excuse anything I’ve just overlooked. I have a 1964 MF 35 - I’ve recently replaced the lift pump (it wasn’t delivering about fuel to the engine which kept cutting out)
I replaced the whole pump. The replacement part was listed as suitable for the 3 cylinder version like I have.
since then, it’s been leaking oil from the bottom of the pump. Not a great deal of oil but enough to notice. The grommet is correctly in place as far as I can see.
it’s bolted on with two different size bolts and washers under each bolt. It’s been tightened but old is still dripping.
Any advise would be welcome. Are the washers causing the issue or is it the grommet?
thanks
   / MF35 lift pump question #2
Welcome to TBN. About the only reason it will leak oil is if the gasket isn’t seated or it is cut. If the lift pump had a crack, that woul do it, but it is a new pump.
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
John Deere 8360R MFWD Tractor (A53342)
John Deere 8360R...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
JOHN DEERE 8R 340 LOT NUMBER 96 (A53084)
JOHN DEERE 8R 340...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
1973 FORD 9000 TANDEM AXLE DUMP TRUCK (A52576)
1973 FORD 9000...
