I have a probably leaking diverter valve on a 35, as when its set to loader and the control is on 'up', the 3ph lifts first, then the loader lifts. If its set to external (ie tipper trailer) it doesnt do this.
I can only conclude that the diverter valve seals are leaking, and allowing pressure to the 3ph as well as the loader rams.
I removed the valve from the block, but I cant see how to get the main cylinder apart. Can someone point me in the right direction? Underneath are two flat screw heads, and little else. The 'back' of the valve - ie at the opposite end to the lever is just a plain disc.
stolen pic:-
this is the same type. Ignore the leaks in the pictures!
stolen pic:-
