MF275 Engine won't stay running
   / MF275 Engine won't stay running #1
dr6462
Massey Ferguson 275
I just purchased a 1970's vintage MF275 with a Perkins diesel. I had to replace the gasket on the top portion of the injector pump and on the side port. Now when I start the engine it runs for about 1 minute and shuts off. I found that if I open the top bleed screw the engine will continue to run as fuel escapes from the bleed screw. I close the top bleed screw and the engine shuts off. Any Ideas?
   / MF275 Engine won't stay running #2
Its sucking air somewhere. When you open the bleed screw you let the air and fuel out. It wont compress air only diesel.
find the leak.
I always like to have an electric 12 volt supply pump. with it just look for the ozzing fuel and fix the leak.
Thanks!!! Makes sence I'll go hunting. I had the entire fuel system pulled apart as I was cleaning it up and fixing many of the little things I found wrong, so I've got my work cut out for me.
12 volt pump sounds like a good idea.
   / MF275 Engine won't stay running #4
If you have a seperate fuel pump test that it is working.The engine will run with out it for a while then when it stops gravity will take over and you can start it back up. Happened to me on a perkins.
Problem Solved!!!! Found the air leak! I had replaced the fuel line with a new one and did not realize there was a rubber seal inside the connector. Took the connector apart and found the rubber seal inside was destroyed. I replaced with new rubber O-Ring put it back together tractor fired right up and kept on running.
Thanks for the advise!!!!!:thumbsup:
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
2000 KENWORTH T800 (A52472)
2000 KENWORTH T800...
