MF231 alternator help please
   / MF231 alternator help please #1
oldbeagle
Durham, NC
Ford 4000 and MF275
MF231 tractor, alt went bad. Got a replacement and put it in, but the wiring seems wrong. With the key on but engine is off, the alternator is getting smoking hot. From my research, a red wire should go to the large terminal at the 12 oclock position, and a gray wire should go to the D+ terminal. Problem is, the tractor does not have wires of that color. There is a wire that comes from the starter. Does that go to the main terminal on the alternator? There is a thinner wire that comes out of wiring harness at the top of the engine. Should that wire connect to the D+ terminal?
   / MF231 alternator help please #2
Your power wire should go to the main terminal, that is likely the wire that goes to the power terminal on the starter then back to the battery. The wire going to the D+ should be a ignition switched 12V source that is off when the ignition is off.
   / MF231 alternator help please #3
Same thing happen to me. Alternator went bad bought a new one. But the wiring is different. Did you fixed yours?
   / MF231 alternator help please #4
Why not use a alternator/starter rebuild service? Usually cheaper and you won't have the incompatibility issue.
Or, watch this and do it yourself...alternators, regardless of brand are similar...rotor, stator, rectifier, voltage regulator, brushes and bearings....
alternator repair - Yahoo Search Results Yahoo Video Search Results
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A52128)
Rhino FS15...
2008 Suzuki XL7 SUV (A50324)
2008 Suzuki XL7...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
CRESCENT SUPPLY 20 CONTAINMENT TRAILER (A50854)
CRESCENT SUPPLY 20...
2016 CATERPILLAR CT660 TRI AXLE DUMP TRUCK (A51222)
2016 CATERPILLAR...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
