MF220 Slow Loader
   / MF220 Slow Loader #1
Mike52
Glen Mills, PA
Massey Ferguson 220 Compact Diesel
I was just about resigned to the fact that the loader on my 220 was normally a tad slow. 'Up/down' seems adequate (barely) but 'dump/return' is so slow I could grow a beard by the time it cycles.
Saw a post a few mins ago (about the MF 50 Loader) that said that the tractor hydraulics weren't fast enough to push a loader. Mine too, is running off of the tractor hydraulics. I was wondering....
1) is that true? are the MF 220 hydraulics are a little small to run a loader. Seems to run the 3pt just fine (although that diverter valve to switch it from the loader is a pain...It always seems to be in the wrong position when I reach for the wrong control)
2) is there a better alternative? I had an IH 424 once that had a pump mounted on a front PTO with a big reservoir. The cycle time on that setup was pretty fast. I don't think there's a front PTO available on my 220 and I don't want to put a pump on the back...any other methods for the 220?
I know diddly-squat about hydraulics so feel free to point out even the most commonly known alternatives.
filters are clean and its full of oil (JD Hygard)....
thanks,
   / MF220 Slow Loader #2
Mike,
Do you know what the diameter of the cylinders are?
   / MF220 Slow Loader
again...I don't know diddly about hydraulics but the measurements appear to be:
cyl length: 20"
cyl outside diam: 2 1/2"
piston outside diam: 1 3/8"
these are approximate. I don't have a set of calipers, its raining outside, and I eyeballed them using a tape measure...(at least I wore my glasses!)
   / MF220 Slow Loader #4
Mike,
The reason that I ask what the size the cylinders were because that might give a clue to the problem. If the OD of the cylinders are 2.5", they may be to large for the size of pump that the tractor has. I would say that they are more than likely 2" ID. That would be pretty big for a very low flow pump. This is all just my thoughts because I don't know the pump flow of your tractor or the exact cylinder size. The larger the cylinder, the slower that it will raise, but they will lift more.
   / MF220 Slow Loader #5
If there is a seperate loader valve, take the line off between the bucket cylinders and and valve and make sure there is not a filter disc installed in the valve. If its a MF loader, there used to be one in the in the lift circuit. Someone could have accidently installed it in the bucket circuit.
   / MF220 Slow Loader
Gents:
Good information from all...
Thanks again to all of youse guys (as we say in Philadelphia).
TBN-ers have come through again.
The hoses and piping for the loader cylinders look pretty ratty. I've been planning to replace all of it with new stuff this winter (when I have a little time???). I'll check for proper hookup and misplaced filters. Hopefully, a refurb will improve things a little. If not, I'll be posting again for ideas on hooking the loader up to something other than the tractor hydraulics.
I'll also go thru the manuals and see if I can get a better idea of the pump and cylinder specs....
Can anyone suggest a website that supplies a good tutorial on tractor hydraulics? Its always helpful to "RTFM"....of course, I mean Read The FACTORY Manual....hmmm?
Pickup Truck (A59230)
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A60429)
2024 CATERPILLAR...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
