MF203 - Cannot find engine S/N - Fuel lift pump
   / MF203 - Cannot find engine S/N - Fuel lift pump #1
clamschlauder
Holly, MI
1966 MF 203
I have a MF203, SN JDM659002940 (Made in Detroit per SN plate). I have been fixing things little by little and when I got the tractor a few years ago. It has an electric fuel pump (from autozone in the general merchandise area) instead of the lift pump. Sometimes the hose clamp leaks so I would like to rebuild the lift pump and start using that again. I can find the lift pump kits but they state different engine SN ranges for different kits. Problem is that I cannot find the SN for the engine. There is a nameplate on the top right hand side with AD3.152. There are other numbers that are cast or stamped into engine but none seem to be the right format, see below.
- 37786300 - raised Numbers just to the right of the engine nameplate
- GKN 1842?? - Cast (engine left) Bottom right of the left side
- 2377992 - Stamped, top left of left hand side of engine
- 37111450X - Cast, middle of left hand side of engine
Fuel pump - C.A.V. [DPA 323 0080 MOD] [SET MW49/850/6/21xx] [SER R17604 OH] (Where xx are 2 numbers that have rust over them)
Any feedback would help. Thanks.
David
Mitsubishi Mini Truck, 3cyl Gas Engine, 2WD (A52384)
Mitsubishi Mini...
2018 Gehl R105 (A50123)
2018 Gehl R105...
40' CONTAINER (A51244)
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
(5) PARTIALLY COMPLETED TRAILER RAMPS (A51247)
(5) PARTIALLY...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53473)
2011 New Holland...
