MF20 industrial need help!
   / MF20 industrial need help! #1
blaux61
Ohio
MF20
I am having a problem on my 1974 MF20 industrial. I am getting a bad leak of tranny oil out of the weep hole on the bottom of the tranny case and through the expansion plugs. It is a pretty good leak. I have been topping it off with oil. Prob went through 3 gallons in 15hrs of usage. After checking it and seeing it was up to the level on the stick a ran the tractor. An hour into working I heard and felt a binding in the tranny. I shut it down right away and checked the oil level. It was fine. I can't figure why it is leaking so bad and why it went bad while I had the fluid level topped off. Any help here would be greatly appreciated.
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
John Deere 5075E (A50123)
John Deere 5075E...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
2017 Ram 1500 Crew Cab Pickup Truck (A51692)
2017 Ram 1500 Crew...
