MF180 clutch and hydro problems
   / MF180 clutch and hydro problems #1
lineman71
Circleville,OH
MF 180, Farmall 300
Hoping for some help from someone knowledgeable about the 180 with a two stage clutch. Here's what happened. My clutch started slipping when I was discing a new hay field last spring. Well I finished with the old farmall that never lets me down. So I worked the 180 the rest of the summer just running the baler and rake and teddin. Not pulling anything to make the clutch slip. During the last cut of the yr the aux hydro's stopped working also. So now the clutch needs replaced and aux hydro's too. Not sure if the aux pump works off the clutch could that be my problem?
I'm getting ready to tear into it and fix everything. But I would like to here from someone that has done this to give me some pointers and what else should be repaired while I'm in there. Any input would be appreciated!
Thank you.
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
2020 COLOMBO TM LOT NUMBER 218 (A53084)
2020 COLOMBO TM...
2017 Case IH Magnum 380 ROWTRAC CVT Tractor (A53342)
2017 Case IH...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A53472)
Kubota 24in Quick...
FAKE (A52472)
FAKE (A52472)
New 40ft High Cube 6 Door Container (A53002)
New 40ft High Cube...
