MF135 Torque Specs
   / MF135 Torque Specs #1
Texas Blues
Manvel Texas
Massey 1655 Ford 1700 2cyl, Ford 1600 2cyl Massey 135 3cyl gas
Hey guys, do one of you have the torque specs for a perkins 3cyl gasser? My crappy IT manual doesnt list it, and the manual I bought online only shows the diesel version (a British Manual). Im needing the main bolts, conn rod, and head bolt torque specs. Finally starting to put this motor back together, I am looking forward to getting it running. Thanks in advance, TB
LOL ok, the IT manual is still crappy but I at least found the main bolt and rod torque specs in different paragraphs in there. I was expecting to see a chart with all specs, guess i'll have to read the fine print! Wheres my cheaters......
   / MF135 Torque Specs #3
Perkins AG3-152 engine
Head bolts: 55-60 ft-lb
Conn rod: 40-45 ft-lb
Main bearing setscrews: 110-115 ft-lb
From the MF service manual for MF-135s from Jensales.
Thanks flusher, will be putting those specs to good use this weekend. Already put the crank in, will be putting the pistons and rods in next.
Vintage Signs (A50324)
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2019 INTERNATIONAL LT625 (A52472)
2019 INTERNATIONAL...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2016 Chrysler 200 Sedan (A50324)
2016 Chrysler 200...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
