MF135 Three Point shudders and only raises 75%
   / MF135 Three Point shudders and only raises 75% #1
lrkellogg93
Kubota BX
Hi All,
I've owned my 1970 MF135 for about a year now. I did full fluid replacement when I bought it, and the hydraulic filter had completely disintegrated (I assume it was original).
Anyway, I went to hook a dirt scoop on this summer, and noticed the highest the three point arms would go, didn't seem high enough. Unloaded, with the three point arms as high as the pump will take them, you can still lift them both up with your hands another 4 to 5 inches. And interestingly enough, right before the arms "top out", you can see the arms "shudder" for a second or two before coming to a stop.
To be clear, the arms will lift plenty of weight, just about 5" lower than what they should have from the factory (loaded or unloaded).
Draft control lever is as high up as it can go, and bolted in place.
Anybody have any idea what would cause these symptoms? I'm looking for a place to begin troubleshooting, and wanted to get input from others before diving in.
2011 Toyota Corolla Sedan (A50860)
2011 Toyota...
2022 Club Car...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A48081)
2013 International...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
