CharlieDelta
Bronze Member
In the process of bleeding my MF135 because of starting problem loosened the fuel lines near the injector. I also loosened the 3rd rear most injector line. When I screwed it back and did the bleed process again and then tightening the nut the not tightened right down till there was no thread. As a result fuel is squirting out despite the nut being tight and the fuel line being seated.
Its looks like I have gained a extra 1/4 inch of space and the nut covers the thread all the way unlike the other injectors which have at a 1/4 inch of thread exposed. It does not appear that I have damaged the end nipple on the fuel line.
Did the MF135 have a seal or olive in this nut? Because it currently wont tighten sufficiently to prevent the fuel squirting out? The only other option is a new injector fuel line.
Any ideas how I can fix this problem?
I also wondered if I have to replace the injector line with a steel/aluminum line or does a flexible fuel line to the injector work?
