MF135 draft control rod help
   / MF135 draft control rod help #1
rosie48188
mf135
Hello, I have MF135 and the lift stopped working. I took draft lever cover off and saw the hydraulic valve lever pivot mounting screw missing and lever no longer activating pump. Then I remove lift cover and see draft control rod round part broke off. I have new draft control rod, but cannot see how to get the old one off the shaft it pivots on--- is that shaft pressed into another part, or how do I get to it? Maybe I need to keep taking apart more of that linkage from the cover? any guidance appreciated-- thanks
I am looking at the manual, but this part of the assembly is not so clear to me
I figured it out--- a retaining ring that would have been a lot easier if was traditional snap ring to use pliers on. Anyway, all back together, and working fine
2023 New Holland CR10.90 Combine - Engine Hours - Separator Hours (A53472)
2023 New Holland...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
JOHN DEERE RC7 R LOT NUMBER 224 (A53084)
JOHN DEERE RC7 R...
5ft 3 Point Hitch Bog Harrow (A51573)
5ft 3 Point Hitch...
2019 JOHN DEERE 8245R LOT NUMBER 187 (A53084)
2019 JOHN DEERE...
378487 (A51573)
378487 (A51573)
