Oil & Fuel MF135 Clutch Inspection Plate Drawing
   / MF135 Clutch Inspection Plate Drawing #1
CharlieDelta
Bronze Member
Australia
Massey Ferguson 135
I made a clutch inspection plate for my MF135.
I have scanned the plate. I then cleaned the scan up in a drawing program. I would add 3 to 6mm to the edge since its rough ground with a angle grinder. Please check the hole sizes and location they seem alright on my MF135 but had to file some holes to get a perfect alignment
Print out as original size and it should be pretty close.
I used a gasket and drilled a hole for a cotter pin to drain the leaking from the main seal and drip the oil away to protect the clutch.
Please report if the drawing is crap then I will remove the file if its wrong. Mine is screwed on so I am sure it will be OK. I dont know if there was differences between all the different models of the MF135.
  • clutch inspection plate.pdf
Pallet of (4) 10 Lug Misc Wheels (A51573)
Pallet of (4) 10...
1270 (A50490)
1270 (A50490)
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
