MF1246 Loader quit working then went up when I tried to lower it
   / MF1246 Loader quit working then went up when I tried to lower it #1
masseytrouble
Massey Ferguson MF 1250
Hi,
I have a MF1245 loader on a MF 1250 compact 4x4 tractor. I was mowing with a 5' brush hog and using the loader bucket to push saplings over. The engine started to overheat and I lost all hydraulics (the brush hog went to the ground and loader did not work at all). I let the engine cool off and restarted engine, still no hydraulics. I dropped the mower and drove to house (luckily loader was about 3 feet off ground). I tried to work loader a bit but it would do nothing. Then while I had the control lever up, so as to lower the bucket, THE LOADER WENT UP and continued going up when I pulled the lever back down. The bucket hit the header above my garage door. I shut the engine off before much damage was done to garage and waited for loader to come down on its own. Again it would not go up or down. When I disconnected the loader from hydraulic system, the three point hitch worked again. This tells me the system is one loop and something in the loader control is blocking flow to three point and to loader. Has anyone experienced something like this? What is best way to disassemble loader hydraulic control?
   / MF1246 Loader quit working then went up when I tried to lower it #2
Try reconnecting the loader quick connects and making sure they seat properly. More than likely the 3ph is run off the loader's power beyond.
20ft Shipping Container (A51573)
20ft Shipping...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A53472)
Kubota BX2680...
New Bulk Lot Chain Slings (A53002)
New Bulk Lot Chain...
New/Unused Agrotk Horizontal Band Sawmill (A51573)
New/Unused Agrotk...
Electric Mobility Scooter (A51694)
Electric Mobility...
