MF1010 conversion to altenator questions
   / MF1010 conversion to altenator questions #1
handirifle
Veteran Member
Central Coast of CA
Massey Ferguson 1010
Mine is a 1995 MF1010 with generator. I have had the generator checked out and it is good, but low voltage light stay on until it's revv'd to around 2K. Plus it does not recharge the battery.
Plus left of the steering wheel, where I assume, the regulator is, gets hotter'n crap. I would like to convert this to an alternator, and have been told one wire is the way to go. My questions, are what is the amperage output SUPPOSED to be on the generator? If I do not have an ammeter, just the light, should I ADD one and forget the light?
If so, what do I do with the wiring for the light? Does one side of the light come from the ign switch? Trying to understand this whole process.
   / MF1010 conversion to altenator questions #2
If the generator is good, is there a reason that you don't just replace the voltage regulator? I've attached the wiring diagram and the wiring is very simple. The regulator part number should be available in the AGCO parts book.
  • MF 1010 Wiring Diagram.pdf
   / MF1010 conversion to altenator questions #3
I looked at the MF Shop Service Manual and it says that the system uses an alternator, not a generator. The part # is GP8122. The output is 12.5A at 4000RPM.
Well they told me it was a generator when they checked it.
Hikojoe
No good answer other thanI don't understand it very well. I am pretty darn knowledgable about engines and transmissikn, but charging systems have always been a weak spot for me.
   / MF1010 conversion to altenator questions #5
If you decide to pursue R&R of the existing system, I've attached a copy of the shop service manual section.
One reason for replacing the charging system may be be cost of replacement parts. The MF regulator (3284127M1) on ebay is $239.
You may just verify the fins on the existing regulator are clean and that it is attached to the panel well so heat can be dissipated. Heat kills electronics.
  • MF1010 Charging System.pdf
If the regulator is attached to the inside of the dash, to the left of the steering wheel, that area gets dowright hot sometimes.
Hikojoe
I see that PDF is for 98-01 and mine is a 95.
Hikojoe
   / MF1010 conversion to altenator questions #9
9B-01 is the procedure number not the year.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
1270 (A50490)
1270 (A50490)
Informational Lot - Shipping (A51039)
Informational Lot...
1996 NEW HOLLAND 3930 WITH LOADER (A51243)
1996 NEW HOLLAND...
2024 Iron Bull 20ft T/A Equipment Trailer (A49461)
2024 Iron Bull...
