Buying Advice MF Power Shuttle and Clutch
   / MF Power Shuttle and Clutch #1
Yankee
Southern NH
Kubota B7610
Question - does a power shuttle actually somehow engage the clutch behind the scene? In other words, is the shuttle lever just an operating convenience whereby the tractor engages the clutch for you as you go from forward-reverse (though obviously the pedal doesn't move), or is the clutch entirely out of the picture? What made me wonder is the slight delay before the directional change.
   / MF Power Shuttle and Clutch #2
Shuttle clutch is completely independent of the ground (foot) clutch. The delay is due the modulation of the hydraulic oil into the clutch pack so the change of direction occurs smoothly.
Thanks - I wasn't sure. I found a Wikipedia article on the topic. It basically said there were two types, one that used multiple shafts and a clutch, the other a planetary gear arrangement. So, the bottom line is that you don't avoid the clutch as a wear-and-tear item on a power shuttle.
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
2011 PARKER TRAILER 35FT DOVE TAIL GOOSENECK (A52472)
2011 PARKER...
New/Unused AGT YSRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
