MF Owners...I need some help
   / MF Owners...I need some help #1
Rford
KC
1966 Ford 2000 Diesel 8sp
I think I may have figured out my 3PH issue but I need someone to take a look at their MF and help me out.
There is a hydraulic control valve in front of the driver's seat that has something to do with how the oil flows. The lever has three positions according to what I can figure out. But I don't know which is supposed to control the 3PH.
I'd be very grateful if someone could tell me if its supposed to be left, center or right (when seated, facing forward) to operate the 3PH.
Thanks in advance.
   / MF Owners...I need some help #2
It would help to have a model and year number
Sure would...jeez. It is a 231, probably mid 90s. I figured it out. There is a hydraulic selector valve in front of the seat. It can be switched between orafices, I don't know exactly what they all do, but somehow the lever got moved and basically shut off the fluid to the 3PH. Put it in the "up" position and the 3PH hydraulics are back in good order....
   / MF Owners...I need some help #4
Moving the lever all the way down and toward the front of the tractor will allow you to run the FEL (at least that's what mine does). Having the lever straight up and down (in the middle) allows you to run the 3 point hitch.
2017 Ford Expedition SUV (A50324)
2017 Ford...
2014 Caterpillar 257D Compact Track Loader Skid Steer (A50322)
2014 Caterpillar...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2007 MACK GRANITE  TRI-AXLE DUMP TRUCK (A51222)
2007 MACK GRANITE...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
