MF 65 with power adjust rims
   / MF 65 with power adjust rims #1
glinka
Lansing,Mi
MF 65
I have a diesel MF 65 with power adjust rims that are rusting out. The tires are 13.6 x 38, which I'm told would be on a 12 x 38 rim. Can't find any used, they say these are hard to find because people filled with water and chloride. Leaking caused most to rust. Buying new runs around $400 per rim. I need both replaced. Is there some other rim I could go with or is it too much change to do?
   / MF 65 with power adjust rims #2
You might be able to find some non power adjust wheels at a tractor wrecker. Might even find some good used power adjust if you expand your search. There's a lot of tractor wreckers scattered around. I think there may also be aftermarket wheels.
Hydraulic Hose Reel (A49461)
Hydraulic Hose...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2017 TRAILSTAR END DUMP TRAILER (A50854)
2017 TRAILSTAR END...
434669 (A48836)
434669 (A48836)
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
