MF 65 Seized Rear Wheel
   / MF 65 Seized Rear Wheel #1
MichMan
SE Michigan
1987 JD 750 4WD
This MF has been sitting outside for 2 years now. The motor was covered and it turns over fine. The left rear wheel will not turn when jacked up. It turns just a little. Anyone have any idea where to start? Serge.
   / MF 65 Seized Rear Wheel #2
My bet is the brakes are frozen.
   / MF 65 Seized Rear Wheel #3
Stuck brake....First I'd try pulling it a few feet (with another tractor or a truck???) If that doesn't break 'er loose, next step is penetrating oil. You'll find it darn near impossible to remove the brake drum while it's stuck. Also, I've "un-stuck a couple with more drastic means. Use some sort of large "punch" (ie a steel rod, ect) against some part of the rim/wheel assemble and hit (in direction of rotation) with a BIG hammer to shock it loose.
Thanks guys. I have tried pulling it backwards several times, but can't pop it loose. Next step-pry bar.
The pry bar did not work. I think I got much more "breaking" ability by jerking the whole thing with my JD. Must of bounced it hard about 2 dozen times. With those big lug tires on the Massey biting the ground, you'd think she would bust loose. The problem is I have this MF sold if I can pull it onto the trailer. Think I'll try to spray some PB in there and see what happens in a couple days.
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
1270 (A50490)
1270 (A50490)
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
Wesco Hydraulic Foot Pump Hand Truck (A50325)
Wesco Hydraulic...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
