MF 50 Value
   / MF 50 Value #1
CRE1992
JD 790, MF50
Hi, I have a 1958 Massey MF50 which I am considering selling. It runs well, the valves have been adjusted, the entire ignition from coil to spark plugs is new, it also has all new fluids. The carburetor has been completely rebuilt, the starter has a new bendix drive and the engine has a new belt pulley. It has an isolator valve to be able to use a snow plow in the front. The three point works without a problem and is extremely strong. The tires are all 90% except for one front which is new. The rears are also loaded. All of the gauges work.
It also has a completely rebuilt (completely sandblasted and repainted with rustoleum, and all new hardware, including rebuilding the lift cylinder) sauder front dozer/snow plow which has had the frame modified to fit the MF50 by a professional welder and machinist.
Can anyone tell me approximately how much they think it is worth for just the tractor, or the tractor and snow plow together as a package.
   / MF 50 Value #2
id say the tractor is worth from $2500 to $3500.
   / MF 50 Value #3
I recently traded in a Massey Harris MH50, which I believe is very similar. The tractor was rebuilt about 6 years ago and ran well, but it didn't have all the parts rebuilt that you mentioned. And it didn't a plow or anything. When I negotiated the price of the tractor, I kept the MH out of the negotiations and only mentioned it at the end, so I feel what they gave me for a trade was a reasonable estimate of it's actual value. They gave me 2000. I ago with the previous post, it'd probably be work 2500 to 3500, perhaps more if you can find a really interested person. Those are great tractors and really exemplify how well built things were back then.
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
2020 FREIGHTLINER M2 26FT STAKE BODY (A59575)
2020 FREIGHTLINER...
