MF 50 stuck rear end locked up
   / MF 50 stuck rear end locked up #1
tococattle
MF 50
While mowing my MF 50 locked up on the road ,tried every gear tractor would not move (rear wheels didnt turn)had to pull off road with the pick up as iwas pulling it in neutral the left rear wheel turned forwards and the right rear wheel turned back wards no grinding noises present, but I am lost, would appreciate any help
T Coble
   / MF 50 stuck rear end locked up #2
:welcome:
Sounds like you may be locked into two gears and may have to pull the tranny cover to get the gears separated (and the fork reattached to the shifter lever).
Did this happen when shifting from forward to reverse, or reverse to forward? When the shifting fork gets a bit worn, I've had it happen before and would double clutch when shifting gears (that is push the clutch down to shift out of a gear, let up while in neutral, and back down to put into another gear).
   / MF 50 stuck rear end locked up #3
Remove the oil fill plug (near shifter) Look straight down, and you will see a larger gear. It'll need to be pried forward to get unstuck from reverse, and rearward to get unstuck from forward. Try to make certain you DO NOT pull up (even slightly) on the shifter while changing gears. Get in the habit of pressing DOWN on the shifter while making gear changes, and that will minimize the chances of hanging in gear.
2019 KENWORTH T880 (INOPERABLE) (A48992)
2019 KENWORTH T880...
MILLER CP-302 WELDER (A48992)
MILLER CP-302...
2020 Ram ProMaster 1500 Van, VIN # 3C6TRVAG5LE100108 (A48836)
2020 Ram ProMaster...
Wolverine GB-11-72W Skid Steer Grapple Bucket, 72W (A47371)
Wolverine...
2011 FREIGHTLINER CORONADO (A48992)
2011 FREIGHTLINER...
2005 Ford F-350 4x4 Crew Cab 8ft Dump Truck (A48081)
2005 Ford F-350...
