MF 471 stuck in gear and loader problems same day
   / MF 471 stuck in gear and loader problems same day #1
Lars6
Mf 471
I need some experienced help here! My 471 4wd with the 12-4 gearbox started having trouble lifting the loader without ramping up the rpms, even when empty when I was using it one cold day to move some gravel. It was reading low on hydraulic fluid so I put some in but didn't help at all. The bucket was still rotating fine and had down pressure, brakes, steering,PTO,and 3 point all seem ok. I parked it and came back the next day and it is now stuck in a forward gear as well as having the loader issues. So I drained the oil, cleaned the strainer which looked fine,put in a new filter and oil but still the same problem. It had started a small leak on the line into aux pump when baling hay over the summer but only when it was hot and working hard. Now that area has a persistent leak. We disconnected the compression fitting but it looks like it's leaking from the next fitting which might have an O ring that needs replacing.
Next problem, I'm not sure how to access the gear box since this has a cab and everything I can find online is for those without. We tried driving it a little to see if that would free things up but no luck. The left shifter (hi low rabbit turtle) works fine but the right hand (123R) won't move freely.
Any and all help greatly appreciated!
2022 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2022 JCB HM180T...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
STIHL TS420 CUTQUICK SAW (A50854)
STIHL TS420...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A51039)
2018 Dodge Ram...
Stump Grab Bucket (A50322)
Stump Grab Bucket...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
