MF 4253 info?
   / MF 4253 info? #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
I'm looking at to purchase a '97 MF4253 with 4350 hrs on tach that owner passed away & his heirs have offered it for sale. It's 2WD has a cab & FEL It has sat idle for several yrs & won't start. I noticed from viewing serial # tag this unit was built in England. I realize it's highly probably due to ULSD that inj pump will require being cleaned/resealed. Do these model tractors have any known problems? I'm also looking at to purchase a '84 model 250 2WD in similar condition & it won't start either.
I've owned/repaired several different brand of tractors but not any MF's.
Thanks for any info.Jim
   / MF 4253 info? #2
That tractor is a beast and still a fairly simple tractor. Very few problems with all the tractors built in Coventry, England. If the price is right it’s a tractor that will last a long time. I’m sure you looked at the tractordata specs.
   / MF 4253 info?
Thanks for your reply. Yes I checked Tratordata spec's. The built in England concerned me but as with your report I recieved positive replies about this tractor from another discussion forum. I guess thing to do is see if I can get it purchased.
Thanks again,Jim
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Forerunner 10-16.5 N.H.S Tires and Rims (A50322)
Forerunner 10-16.5...
1963 Trail Mobil Tanker (A50514)
1963 Trail Mobil...
New Holland 155 Hay Elevator (A50774)
New Holland 155...
2020 CF Moto 500 Trail (A50514)
2020 CF Moto 500...
