docrocky
- Joined
- Jul 18, 2011
- Messages
- 207
- Location
- NW Ohio and SE Michigan
- Tractor
- Oliver 880, Ford 8N, Ford 9N, Farmall Super C, MF 205, Ford 4400 FEL, Ford 4500 FEL/BH, Cat D-6 Dozer(1957)
I recently obtained this tractor from a good friend of mine. It has a front end loader which makes access to the engine oil intake cumbersome. I had to feed a funnel from the top of the lift arm. In so doing when I was finished I failed to put the oil stopper cap (black rubber plug) into the intake. (I will provide photos of what I aam describing since I don't have the terminology of the parts). I then proceeded to disc about 2 acres of saandy loam which was fairly dry. On my last pass the engine started stalling out. I though I was low on fuel, but it was ok. Oil pressure seemed ok (quick glances) and the temp gauge remained mid was in the green. As I tried to start it , it hardly wanted to turn over. I was able to get it back to the barn which was about 300 feet away. After parking it a few minutes, it wouldn't turn over. At this point I found the oil cap in my pocket. The oil level was ok on dip stick check and the engine was not over heated. I then waited about a hour and she turned over easier and started but then there was a distinct knocking. I quickly turned it off.
Question: How does the oil pump function in this model and by running it with the cap off, was there a problem of no vacuum and did I do internal damage to the valves/pistons etc.
