MF 40 industrial
   / MF 40 industrial #1
ragalac
Hi I have just bought a MF 40 industrial with a shuttle shift and I cant make it move forwards or backwards. Does any one know how to drive one? there seems to be 2 pedals on the left hand side and 2 pedals on the right hand side. the seems to be 2 gear levers
   / MF 40 industrial #2
G'day Ragalac and welcome to TBN can you post some pics of the setup but i am guessing that you have a six speed g/box ( 3 speed and hi/lo) that is what your two gear levers are you will need to have both of them engaged for the fwd/rev shuttle to work. As far as the pedals go you prob have a foot throttle and brake and a loading brake that disengages the trans when you use it without moving the shuttle lever, sometimes they can stick and keep the unit in neutral i have freed them by operating them a few times with my size 11 and a bit of good luck. Keep us informed of what happens and good luck
Jon
   / MF 40 industrial #3
Hi there,we have a MF 40 industrial too and at first had troubles.
The right side has something that looks like a stirrup or 'U', if you push on the left it is reverse and right is forward...I think.:laughing:
Anyway that is how the shuttle shift works.
The middle is simply a foot throttle but won't make the tractor move.
On the left side is the two brake pedals.
As to the gear levers,the left (longer) lever is....hi-lo I think(going by memory here as the tractor is 300+ miles away) and the right lever is the gear.
The tractor seems a good one,at least in our case.
My issue is working out the three point hitch/draft control but I think I have it figured out....push the draft control all the way up and THEN set your three point hitch...
Oh and runnig over things and getting flat tires....:laughing:
Genie GTH1056 (A50120)
2013 Ford F-550 4x4 Horton Ambulance (A50323)
2013 Ford F-550...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
Killbros 385 Gravity Wagon (NICE) (A50774)
Killbros 385...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
