brandon327
- Joined
- Dec 14, 2008
- Messages
- 19
Question #1
What are the 2 knobs under the seat for? I think they go to the 3 point hitch but what do they do?
Question #2
I hooked to our disc for the first time today and they tractor will pick it up plenty high in the front but not it in the back. I set the backbone all the way in and tried it in all the 3 holes and nothing helped. I think the backbone is too long. So i tried the backbone off of our John Deere which is shorter and i could get it short enough to get it up off the ground. But with either backbone no matter how i set it when i started disking the front set of gangs sunk in the ground then the rear of the disk came completely off the ground. So i adjusted the backbone ever way and nothing helped. It seems like the 3 point hitch goes to low. When you go to raise the 3 point hitch it is either up or down there is no in between? I think there are about 6 or 7 hitch postions and it does not make any upward motion till it gets to about 5. I do not have any of these problems out of the John Deere. I eneded up hooking the disk to the JD and using it. I am starting to think i made a mistake buying the MF. But i do like the MF more than the JD.
Question #2
