MF- 360 Dual Stage Clutch Only Working As A Single Stage Clutch.
   / MF- 360 Dual Stage Clutch Only Working As A Single Stage Clutch. #1
rebragmd
Jonesborough, TN
Ford 1715, NH TC33D, MF-360, Ford 601 Work Master
The PTO cannot be engaged while the tractor is running. The clutch only works as a single stage clutch. Someone by-pass the no start switch so they could engage the PTO with the tractor off and then start it with the PTO engaged. If you try to engage the PTO with the tractor running, it will just scape gears and you cannot engage it. Pushing in the clutch will disconnect the engine just fine and letting it out will engage the engine just fine, but not the PTO as described.
Is there anything that can be done other than replacing the clutch?
What could have happened to one stage of the clutch?
Please help. Thanks!
ROME AH-240 LOT NUMBER 130 (A53084)
ROME AH-240 LOT...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
New/Unused Two Post Car Lift 10,000lbs (A51573)
New/Unused Two...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
