Oil & Fuel mf 35 fuel issue
   / mf 35 fuel issue #1
earljam
makanda, il
tractor king 254
Howdy folks, I have a 1961 mf35 3 cyl. that won't start. I have bled the primary and secondary filters but can't get any fuel at the bleed points on the fuel pump. I have seen other threads where they can't get fuel at the injectors but I haven't found this issue anywhere. Has anybody else had this experience?
   / mf 35 fuel issue #2
is one of the filters a 'water filter' and has it gained so much water that it is now plugging the flow of fuel?
   / mf 35 fuel issue
Thank you, that could be it. I just bled them, didn't change them.
   / mf 35 fuel issue #4
When was the last time the filters were changed? Do you have air free fuel flow at the discharge of the filter next to the injector pump?
   / mf 35 fuel issue
Changed them just now but I'm having the devil of a time getting the cartridge housing on the first filter (farthest from the pump) to stop seeping.
   / mf 35 fuel issue
looks like it seeps on its own at the bottom where I replaced the o ring and when I pump it it comes out around the flange rather than at the bleed point
   / mf 35 fuel issue
replaced gasket, same issue - pretty sure I'm not over-tightening and crushing the gasket and I've cleaned where the gasket seats. Still seeps put around the gasket when I pump it up.
   / mf 35 fuel issue #8
Massey Ferguson 35? looking at...
www.agcropartbooks.com -> guest (click) view books)
entering 35 and selecting Massey Ferguson
i get loaders (front end loader), tractors, combines, and everything else... and it looks like there listing 2 different tractors one an industrial tractor and another a agricultural tractor.
pictures of what you are trying to deal with might help, as well.
   / mf 35 fuel issue
Small ag tractor, 3 cyl. Perkins diesel. Cannister holding fuel filter weeps when I use the lift pump - tried two gaskets, cleaned surfaces..can't get fuel out the bleed nut because it leaks at the cannister/housing interface through the rubber gasket
   / mf 35 fuel issue
Well I'll be...looks like the housing itself is warped.
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
2014 PJ TRAILER 40' TANDEM AXLE GOOSENECK (A52472)
2014 PJ TRAILER...
KUBOTA M7-132 (A53084)
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
