MF 35 deluxe, clutch wo'nt fully disengage
   / MF 35 deluxe, clutch wo'nt fully disengage #1
tater digger
covington, louisiana
Massey Ferguson 35 Deluxe
I recently bought a '60s model 35 with the continental z134 engine, the clutch, which worked okay at first, no longer disengages fully. I have to turn off the engine to get it out of gear or to stop the tractor. I have'nt heard any noises which would indicate a bad throwout bearing. The manual says that an adjustment can be made by removing the clutch pedal shaft and turning an adjuster inside the gear housing with a long screwdriver. Does anyone know if this adjustment would work or will i have to split the tractor to get at the pressure plates and throwout bearings?
Oops, just re-read the manual, a bar through the hole on the end of the clutch shaft is used to turn it after the pedal is loosened.:eek: Also it may be a TO-35 but it is definitely a deluxe (ground pto). Sorry about the goof, it's late and i'm sore from riding up a pile of logs and debris while standing on the clutch and both brakes. I'll get out there tommorrow and try the pedal adjustment.:rolleyes:
   / MF 35 deluxe, clutch wo'nt fully disengage #3
Tater:
It depends. How much free pedal clearance do you have?
The exterior linkage adjusts the free pedal clearance only. It should be about 1".
If the clutch is not worn out, it can be adjusted externally from below wut it takes time patience and the proper tools.
If it is badly worn neither adjustment will be of much help.
Following is a better Forum for MF mechanical advice:
Massey Harris & Massey Ferguson Tractors Discussion Board
Dean
I went out and adjusted the pedal today and that did the trick. Seems the clutch does'nt disengage untill the last 1/2 " of travel before the pedal hits the footrest. I will probably need a new clutch and adjustment soon because with the two stage, it should disengage the wheels halfway down, then pto/hydraulics all the way down.
I checked out yesterday's tractor , that is a good forum, Thanks
   / MF 35 deluxe, clutch wo'nt fully disengage #5
My clutch is sliping.Can I clean it or does it need replacement? It is the dual clutch type on a model TO35
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
City of Buckhannon - 2000 Chevy 2500 (A52384)
City of Buckhannon...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2001 Volvo VNL Truck, VIN # 4V4N19JF51N250353 (A51572)
2001 Volvo VNL...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
