MF 30 power steering problem.
   / MF 30 power steering problem. #1
ndmarks
dublin, ca
mf30
The power steering on my MF30 seems to work fine when cold but once the tractor warms up the PS seems to go away. The manual says use fluid meeting spec MF M-1129A. I found out that WalMart evidently changed their fluid and the WalMart fluid I added no longer meets M1129A (it does meet M1141, M1143, and M1145) Would this fluid be the problem? I went out and bought some fluid that does meet M1129A and will add it when I can. In the mean time is there anything I can add that would make the PS work better until all the old fluid works it's way out? The only way I know to drain the system is to either pull the PS pump (bolts are hard to get to) or I can try to syphon out some of the old fluid. Any Ideas?
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A55788)
2017 Ford F-350...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2017 TAKEUCHI TL8 SKID STEER (A52705)
2017 TAKEUCHI TL8...
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A54607)
2023 MAXEY G8X...
(4) UNUSED LANDHONOR PINS (A54757)
(4) UNUSED...
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
