JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 3,983
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
My MF 2660 has about 550 hrs or slightly less on it. 2010 model bought in April 2011. Never ever a minute's trouble with that Perkins. Probably the most reliable thing about the tractor... Anyway on 11/27/22 at about 38 degrees outside air temp I started it up with no problem and went about using it for 1/2 hr grapple working some limbs. Warmed into the 50's while working. Then I moved to a different field to do final bush hogging of meadows before winter. That's when the smoke started. Heavily smoking blue/white smoke for several hundred feet of downhill travel. Could find nothing wrong. Oil at full mark. Temp normal. Running smooth. No warning lights on or blinking or momentary. Same as always except for the smoke. When smoking it was heavy not just a hint but a LOT of smoke. Nothing like I saw one time when a diesel was burning crankcase oil (black cloud about like a plane crash) -- not at all similar. During the next 90 minutes of work cutting heavy wet grass and weeds everything ran totally normal. No issues but once in a while a period of smoking. ALWAYS GOING DOWNHILL or just after downhill travel. Never smoked going uphill.
Background: The fuel tank was down low to probably 4 or 5 gal when I added one 5 gal can of red dyed off-road diesel the night before the smoking started. That fuel was from a high volume regional supplier at their terminal and had sat in the can about 1 month. The can was "clean" in that it is never used for anything but diesel and kept closed in a garage. Next morning, the day of the smoking, I added one more fresh can of fuel (not off-road, just purchased from a truck stop that morning) which brought the gauge up to a little more than half full.
Note also that I had my 2660 modified in 2011 when new because the #$%^& thing would not climb a 45% slope with 1/3 of a tank of fuel (!) Stalled. Starved for fuel. The dealer put a T with stop valves in the legs such that one pickup was in the back and one in the front of the tank. That solved the hill-climb starvation of fuel issue.
[I was cussing mad about that and a dozen other issues at the time in a brand new tractor right off the showroom floor. Another long story.]
Now, all that said, my theory is that this smoking is/was a fuel issue. It only happened going downhill or just long enough after downhill for the fuel to get picked up and in to the injectors. It cannot be crankcase oil related (burning that would be coal black smoke.) I know of no path for hydraulic oil to get into the combustion. Total cumulative smoking time out of a 2 to 2.5 hour running time I estimate was a few minutes, not just a few seconds.
What say you world of experienced diesel operators ? Why was is it smoking ? [I say "was" because after a couple hours operation there was no more heavy smoking but 1 or 2 times I did notice a very light smoking for a few seconds... obviously not staring at the exhaust for 2 hours. When it was smoking heavily it got your attention without looking at the exhaust.]
