MF 2605H 3pt hitch is stuck constantly pumping UP
   / MF 2605H 3pt hitch is stuck constantly pumping UP #1
midwestguy
MF 2605H
Low hour 2605h.... bushhogging and lifted the 3 point and tractor is now stuck in "full up mode" - HA. It's constantly pumping up. After shut off, tractor will still not relieve the pressure on the 3 point hitch.
Where do I start to troubleshoot this? Thanks.
   / MF 2605H 3pt hitch is stuck constantly pumping UP #2
I’d start by checking the hydraulic fluid level - make sure it is full.
Do all of the other hydraulic functions operate properly?
   / MF 2605H 3pt hitch is stuck constantly pumping UP #3
I am not that familiar with the 2605H. However I believe that all came with draft control. It would be the taller of the two outside levers next to the 3point hitch controls. The plastic handled unit is the position control, the taller of the outer levers is draft control, and the smaller of the levers is reaction control. Draft control is used with ground engaging implements such as plowing. Most folks don't use it. I believe it should be as far forward as you can make it. The short lever is response control it determines how fast your 3pt responds. Move it one way and the 3pt will gently move, move it opposite direction and it will move rapidly.
I believe that your draft control (middle) lever is in the wrong position. Move it to the opposite end of its movement and see if that helps, if not them move it to the opposite end of its travel and try again.
Also please post back with your findings. If your having this problems, most likely others will have the same issue. It is helpful for others to see how you solved this.
   / MF 2605H 3pt hitch is stuck constantly pumping UP #4
Are you saying it wont even lower now with the tractor off?
Two things to check.....regarding being up and still pumping....its probably a feedback linkage adjustment. IF its not dropping even with tractor off....see if it has a drop speed valve that is closed. Usually a knob under the seat
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2014 Doyle Dry...
TRAILER AXLE (A51244)
Farm Hand Silage Wagon (A50515)
Farm Hand Silage...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
