65plymouth
Guys. Just bought a 255 with 236ci perkins and 8 speed. I bought it out of state sight unseen (other than pics and video from the dealer) and had it shipped to me.
A few questions.
1) started the tractor and warmed it up. Seems to have a small fuel leak from the fuel pump (I assume gasket) on the side of the engine. Also appears to have a decent oil leak from the crank case dip stick tube. Could it be a o-ring?
2) tractor does not have multipower. After driving it around and warming it up I heard a constant low whinning noise from the trans/rear end. When I depress the clutch pedal all the way, the noise goes away completely. Let it out and it reappears. Thoughts on what this noise could be?
3) front wheels are adjusted very wide. Seems simple to bring them back in. Tractor seems to have a TON of camber. Top of tires are way out. Is this normal or a sign of worn spindles?
4) Want to change all the fluids. Anyone know the correct fuel filter (Glass bowl on bottom) for this tractor. It has the 4.236 perkins. What about the hydraulic filter?
5) diff pedal seems to be locked down. Any idea how to release it. I am assuming the diff is locked with the pedal in the down position.
I appreciate the help.
A few questions.
