MF 255 - lack of heat in the cab
   / MF 255 - lack of heat in the cab #1
papamoose
Tunis, Ontario
Massey Ferguson
I have a 1982 MF 255 diesel tractor and am I experiencing problems in getting heat in the cab.
I have put a new rad cap and new thermostat but still minimal heat.
I noticed that the rad is not building pressure as the hoses are not getting hot ( can easily touch any of the hoses).
There are no leaks and all fluids are topped off. Previous owner had changed the water pump.
The heat gauge goes about 1/3 into the yellow. I have covered the front part and the sides in the hopes of gaining some heat, but still minimal heat.
Hoping someone can shed some light.
   / MF 255 - lack of heat in the cab #2
Diesels take a while to warm up.You won't warm them idling. You have to start working them gradually.
Are you using the correct thermostat (~195F) and the correct rated pressure cap? Do you have a shutoff valve in the cab heater circuit? Some tractors do (they sometimes call them summer valves because you turn them off in the summer).
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
UNUSED MOWER KING SSFCAG Y HD HYD AUGER (A51248)
UNUSED MOWER KING...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
UNUSED CFG INDUSTRIAL XZ20R EXCAVATOR (A51247)
UNUSED CFG...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
