MF 232 pump shaft removal?
   / MF 232 pump shaft removal? #1
thorkyl
Brazoria County Texas
Massey 45hp
I have a MF 240 with a 232 loader.
The 232's front mount hydro pump shaft has failed.
The shaft is bolted to the crank and goes through the front axle.
How do I remove the shaft from the crank?
I see some bolts but I don't see how to get the shaft off of the bolt plate.
Any suggestions?
TIA
   / MF 232 pump shaft removal? #2
The shaft will be threaded into the adaptor plate, this is a L.H. thread
Thought I would add the how to on this.
I had the rigid shaft.
I pulled the radiator off and the cowlings
I put a bunch of liquid wrench on the threads
Let it sit over night
Then cut the belt
Then made a strap wrench out of the belt.
Think twitch for a horse
image of one here - Rope Twitch in Twitches at Schneider Saddlery
used the twitch on the belt pulley to hold it from rolling over.
used an 18 inch pipe wrench and a 4 foot breaker bar.
Came right off
Total time to pull it all out excluding the overnight wait was about 4 hours using air wrenches.
When I put it back on, I put a spare belt over the shaft and wired it to the cowlings so nothing would touch it. Then if the new belt breaks I don't have to pull the thing down to replace the belt, I already have one on it.
   / MF 232 pump shaft removal? #5
Thanks for the reply, glad things went as planned, couldn't have done it
better myself;)
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2013 FORD F550 SHUTTLE BUS (A52576)
2013 FORD F550...
