Oil & Fuel mf 205-4
   / mf 205-4 #1
koda
muscatine, ia
mf 205-4
i have a mf 205-4 ran out of fuel and now it wont start how do i prime it?
   / mf 205-4 #2
if it has a mechanical lift pump you pump it till the sediment bowles are filled with fuel then spray ether in the intake and keep it running on ether till it starts running on fuel then keep it running to make sure its primed
   / mf 205-4 #3
Do not use ether! After filling tank loosten bleed bolt at injection pump to bleed all air from fitting, then loosten both line nuts at injectors and crank to bleed air out here too, when all air is clear retighten nuts, preheat glowplugs and start engine. This tractor uses a gravity system, has no primer. Is not hard to bleed if done carefully.
   / mf 205-4 #4
G,Day MF1135.
My old dad used to say ether was really good if you wanted to put a noisy dog to sleep but if he saw anyone near an engine with the S,,,,,,,,,T .He would do the same as he would do to the dog.
It is good to clean things with .
Ooroo.
Hutch.
2023 LMC M30018 LOT IDENTIFIER 106 (A53084)
2023 LMC M30018...
66in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
66in Dual Cylinder...
2008 CATERPILLAR 272C SKID STEER (A51246)
2008 CATERPILLAR...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
UNUSED RAYTREE RMSG29-29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
