MF 202 Won't run under load
   / MF 202 Won't run under load #1
nvrodney
Salem, Oregon
MF 202
OK People,
I about give up! MF202 workbull. Will not run under ANY load.
What I have done so far:
1. drained fuel and replaced the complete fuel valve assembly and screens.
2. Brand new carburetor and adjusted just fine.
3. Brand new coil.
4. Brand new distributor, points. cap, rotor, condenser.
5. adjusted the governor umpteen million times.
6. Checked the timing.
7. Checked and rechecked the firing order.
This tractor ran fine and then out of the blue just went south. it doesn't spit, sputter, backfire, etc. at all. runs and accelerates fine just sitting. When I put ANY load on it, as in real use, it just loses power and nearly dies.
ANY HOPE OR HELP????
Thank You
Rodney
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
Hydraulic 80mm Quick Coupler (A52384)
Hydraulic 80mm...
2006 Wabash National 28ft Dry Van Trailer (A51692)
2006 Wabash...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
