MF 202 or 204 - Lost loader hyraulic drain plug and oil while washing
   / MF 202 or 204 - Lost loader hyraulic drain plug and oil while washing #1
TractorsRmyFriend
Simi Valley, California
John Deere 410, Massey Ferguson 202
Hello, I am new to this site. I have a MF 202 or 204. It is gas. Continental Z134 engine. I think it is 40 hp. I lost the lauder arm hydraulic oil drain plug and naturally the oil too. It is located right side of the tractor just under the loader controls. I didn't even know that it existed. Any ideas what type of plug I should use. Is the body of the tractor being used as a reservoir for the loader hydraulic oil? Do you also know where to fill the oil from. The red oil filter next to the controls is the breather. I will try to attach some photos. Thanks.
Similiar tractors : 35, 50, 135 , 150 , 20 , 202 , 204 , 2135 , 2200
Also diesel 203, 205
   / MF 202 or 204 - Lost loader hyraulic drain plug and oil while washing #2
I owned a 202, also called a 'Workbull', for several years. They fit their name as they are hard working industrial tractors, easy on the ages and we could get away with moving 1300 lb bales of hay with someone standing on the back as dead weight. Issues though were traction. I wished I had kept that tractor looking back as it was a good tool for small jobs but would have added rear wheel weights and chains. They command prices of. $3k to $5k in our area in working order.
Of your question, the loader should (is) self contained, meaning it has its own hydraulic fluid. If you're talking about the drain plug on the side of the loader, sort of at the end of the yellow beam at the bottom, could be fitted with a common pipe plug from Home Depot. I'm unsure on the plug thread but have worked on those and do not recall anything being machine thread or metric. Use Teflon tape to seal and try it by hand first.
On loader fluid, we used common hydraulic comb tranny fluid. Do not by the cheapest as there are clear quality differences. Just look at the oe spec the fluid supports. On the cheapest TSC fluid I've found dirt and the coloring indicates not so hot grade, compared to spending $10 more for higher oe spec oil.
Of the difference, 202 to 204, I believe the 204 has a hydrostatic tranny of some sort. The transmissions were prone to issues but only after heavy use. Searching for used Workbulls in the past, most of them either have power steering or tranny issues, or both. Owners would suitably work those tractors into the ground. Make certain to keep your rear transmission oil clean and full. For that fluid you'd best researching the exact oe spec, but again we used common mid grade oil without a hint of issue for years.
   / MF 202 or 204 - Lost loader hyraulic drain plug and oil while washing #3
Both of you have or had a MF202 and I have not. I am puzzled by the discussion. Surely the main hydraulic oil reservoir is the chassis of the tractor isn't it ? 30acres says the loader has it's own hydraulic fluid. If that is the case then there has to be a separate pump dedicated to running the loader ? Please clarify.
   / MF 202 or 204 - Lost loader hyraulic drain plug and oil while washing #4
JWR: The pump on my 203 runs off the crankshaft pulley by way of an adapter plate with an attached shaft keyed to the pump.
   / MF 202 or 204 - Lost loader hyraulic drain plug and oil while washing #5
Aha ! Understand. With a separate pump like that there may well be a reservoir external to the chassis of the tractor for the loader hydraulics. One of the picts looked like the sump might even be the hollow loader frame at the back. OK, I'm not able to help here so I'm backing out of discussion. Thanks.
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
Electric Concrete Mixer (A51573)
Electric Concrete...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
Kubota ZG327 (A50120)
