MF 200 Industrial Shuttle Shift problems
   / MF 200 Industrial Shuttle Shift problems #1
dmhebel
Massey Ferguson 200
Hi,
I have a MF 200 that we have had since new. Its equipped with the forward / reverse shuttle shift pedals, and a high / low two speed transmission. Recently decided to change the very brown transmission fluid. Drained from both plugs, ran a little bit to clear the pump. Added Tractor Supply fluid that said it was compatible with the spec fluid number (Don't have this number with me right now). When I first changed the fluid, the tractor would only move in reverse. After sitting over night, it would move forward / backwards fine. Took it for a test mow, and ran fine for about 30 minutes. Then it would start to slow down and then seem to 'catch' and then move again. Eventually it stopped all together, and had to let it sit overnight. Next day it was fine, although it did slow down a few times back to the shop. Its almost like air is getting in the pump, or its cavitating or something. Any ideas? Bad tranny oil?
Thanks ---
This should have said MF 2200 industrial, it has a 200 loader. Thanks,
   / MF 200 Industrial Shuttle Shift problems #3
Sounds like there is not enough oil in it. Have you checked the oil level in the correct manner?
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
Hydraulic 80mm Quick Coupler (A52384)
Hydraulic 80mm...
2024 Deere 317G (A50123)
2024 Deere 317G...
2018 GMC 2500 4x4 Crew Cab (A52384)
2018 GMC 2500 4x4...
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A51248)
UNUSED WOLVERINE...
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
