MF 20 no hydraulics
   / MF 20 no hydraulics #1
MattU
Lawrenceville, illinois
Massey ferguson MF 20
I've got a mf 20 with 3cyl Perkins gas. It was my grandfathers and has sit for 6-8 years. After taking apart and cleaning the fuel system and rebuilding the carb. The tractor runs beautifully. However the tractor has no 3 point control or power. The levers do nothing, and you can lift the arms by hand and they fall under their own weight. So far I've drained the hydraulic fluid (of which there was a mix of fluid and water totaling about 10gal) and cleaned the hydraulic filter. I also used a couple gal of diesel to flush what I could out of the insides. After reassembling and refilling with the proper amount of hydraulic fluid I still have the same conditions.
I've ordered some books for the tractor but they haven't arrived yet. I really need to use the tractor. Can someone please tell me what to try next and how? I'd hate to dive in blind and mess something up.
So after some careful digging I've found the problem. Under the plate with the dipstick and the response lever. The arm with the rolling pin is sticking. Not returning back when the controls are set in the up position. How can I get this moving freely?
2007 GMC Sierra (A50123)
2007 GMC Sierra...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
2007 FREIGHTLINER M2 BOX TRUCK (A53426)
2007 FREIGHTLINER...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A53426)
2020 CHEVROLET...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51692)
2012 Trail-Eze...
